跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Clear image, but no touch...its not the LCD and its not the connector.
Hey everybody!
I have an Iphone 6s here with no touch...I tried two good known displays (have an other Iphone 6s here to test it) but no luck. Also I soldered the second new connector now...everytime same result, clear image but no touch...
I know, that the Touch-IC itself is on the display, so what should I check for next step now? On the connector, only the right-side is for touch, right? So I checked all filters, wich are belong to the pins of the right-side of the connector, but all have continouity...
Hope you can help me guys,
thank you ;)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Let's back up here...
Was the lack of Touch the original problem? Did you solder two new connectors before or after trying the "known-good" screens? Finally, which filters exactly did you test?
The obvious comment to make here is to insure that your connector is properly soldered in place. Double check all of the pins to insure they connect electrically to the pads.
You are correct that the Touch IC is now on the display. So in your case I would focus on insuring that the Touch IC is getting the power that is needed. Have you looked at the PP5V7_MESON_AVDDH, PN5V7_LCM_MESON_AVDDN, PP1V8_TOUCH & PP5V1_TOUCH_VDDH lines (filters and associated circuitry)?
On the same page of the schematic (pg 30), there is also a section titled "AP TO TOUCH INTERFACE". There are several communication lines that are also filtered. If one of those is damaged or shorted, you would also lose Touch.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Flo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 147
