跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
61 个问题 查看全部
Apps cannot be installed nor deleted after screen replacement+issues
Hi, so I tried replacing the digitizer and some of the usual issues occurred along with some that are quite rare :
1 ~ The old problem of power button not working if applying a short press while it still works if you press longer in order to power on/off the iPad.
2~Apps wiggle when you touch and hold ,the delete bubble is there but then you can't delete the app nor install it using the IPad,but it still works if you install via iTunes,it bothers in case you are interested in apps directly through Safari .
3~Even if the iPad is turned the LCD is black nonetheless (A common issue which can be solved by connecting to iTunes and activating VoiceOver and Inverting Colors from there .
4~~Home button not working .
These problems are common for IPad mini(3,4) ,and I think they are related to the cables of the home button not being placed appropriately ,since when I sometimes touch those flex cables some of these problems are solved like temporarily but then come back.
Can someone give me some instructions to solve especially the broblems ~1 ~2 .
Thank you !
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The no short press power button issue is usually a parts issue---where did you get your screen?
这个答案有帮助吗?
得分 1
5条评论:
From amazon with a pre-installed home button (not the original)
完成的
Amazon/eBay parts are the worst available. Buy from a better vendor, like iFixit, and see if these problems resolve. They all seem related to home button flex soldering on the screen itself.
完成的
It worked fine the first time but then I had problems with the adhesive not sticking well so I had to redo the repairing .
完成的
then you have likely creased the flex. don't ever use the pre-installed crap adhesive from these crap screens. Use Tesa Tape--available from iFixit. Trash that screen, get a good screen, get good adhesive and you can fix this.
完成的
Thanks for the advice !
完成的
添加一条评论
As for 1~ And 3~ in iOS 10 go to settings>display and brightness and turn lock/unlock Off and On .be careful to first connect your iPad to iTunes and turn voiceover and And invert colors from (configure accessibility).
2~ is solved automatically if the above are solved (I hope) ,it happened to me.
3~is probably because of a damage received by flex cables.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 17
总计 821
