跳转到主内容
An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
Why won't my g priv turn on
i have a g priv and nothing shows up on the screen when i go to turn it on. it worked the other day and now suddenly when i tried to turn it on nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
5条评论
Do you see any error lights or is the device unresponsive after pressing the button three times?
完成的
I get a blank screen, a very slight green led light is on and a very very slight hissing sound. It's and electrical sound kind of like the letter p but very faint. I open battery door and it stops. Battery are fully charged using nitecore and verified on another mod. I checked the ribbon inside and it worked for a week. Now it's dead?
All wires look to be sodered correctly. It may be the board? Any ideas?
完成的
Mine is doing same thing batteries are fine and ive hhad it for months dropped it this morning now screen stays black only hear a high pitch electrical like buzzing sound wont do anything no idea how to fix
完成的
Hi I have a g-priv smok touchscreen but sometimes it will have a blank white screen when I turn it on how to fix
完成的
I have g priv 220w smok touchscreen when I turn it on the screen is plane white help
完成的
添加一条评论
18个答案
已选择的解决方案
Press the on button three times. That failing, change the battery.
这个答案有帮助吗?
得分 4
11条评论:
HELP I just bought my third smok xpriv the other two would not turn on they were brand new. Now my third from a different carrier wont turn on iv checked my batteries an made sure they are on correct. Press the fire button five time nothing!!!! When I put the batteries in the vape come on an says smok an goes off...am I missing something
完成的
Mine is all of a sudden doing the same thing too the coloured light flash then says the smok thing and that’s it??
完成的
As the site mentions, put the batteries in. push fire button 5x.
It supposed to startup then
完成的
Thank you yessmokit the only thing that worked. My day is saved!
完成的
I dropped mine and I made took the batteries out and put them back in. It would flash the Smok screen but nothing worked. I hit the fire button 5 times and it booted right up. No issues since.
完成的
显示更多的6条评论
添加一条评论
最有帮助的答案
Take battery's out. Hold all the buttons then replace battery's then turn on
这个答案有帮助吗?
得分 6
5条评论:
Hi there, I put free battery's and change it out and still nothing! Any other suggestions?
完成的
fresh not free sorry for the typo :)
完成的
Worked for me first time thank you so much
完成的
Yes that worked for me thank you i dropped mine in water and the screen won’t work it just has the backlight but i could turn it on and use it up until last night when it just stopped so i charged the batteries in my separate charger (i don’t like charging the vape itself) and still nothing was stressing out but this trick worked your awesome thanks
完成的
GUYS..It's the (DIRTY) pins under the ATOMISER !!! Just remove the atomiser and clean the pins and coil bottom - make sure the coil is pushed firmly in place - and everything will back to normal - no need for button pressing etc. Alternately remove atomiser when fitting battery, then refit
完成的
添加一条评论
Mine won’t turn on but when I close the battery door it does a quick flash of green but it won’t turn on or anything after that how do I fix it?
这个答案有帮助吗?
得分 4
1条评论:
It's dead. Mine makes a small p sound. Slight green lights. It's a piece of cra p the last smok product I ever buy
完成的
添加一条评论
I just bought mine today, charged it up, used it a few times throughout the day, turned the vape off, went to use it again 2-3hours later and NOTHING.. it won't turn on, I see no notification of any lights, I checked the batteries & charged them, at 100% and the device still won't turn on.. I'm confused on why it would suddenly stop working & for what reason?
这个答案有帮助吗?
得分 3
3条评论:
same as me i just lost 50eur? on one day vape?
完成的
Mine too. Fresh batteries still nothing.
完成的
Me too. I bought mine today. Put in fresh, charged batteries but when I hit the power button 5 times like I'm supposed to it wont turn on. I haven't been able to turn it on since I bought it today.
完成的
添加一条评论
Mines won’t turn on at all charge battery and then bought a battery charger still nothing lights will come once I put it on the charger but after that nothing
这个答案有帮助吗?
得分 3
添加一条评论
Same, SMOK &&^&^$^ SUCKS!!!! CHEAP ASS POS MADE BY CHINESE KIDS FOR 10 CENT AND CHARGE US 75$ FOR IT. I HOPE SMOK GOES BANKRUPT THEY ARE A $@$*!& COMPANY. DO NOT BUY THEIR PRODUCTS UNLESS YOU LIKE THROWING YOUR MONEY AWAY.
这个答案有帮助吗?
得分 1
1条评论:
I spent $110.00....4 months later it died.
完成的
添加一条评论
I've had the same problem numerous times with my g-priv ProPod. Think I've finally found a fix. I removed the battery and put it on charge, I was surprised to see the screen still on. But then I just unplugged it and reinsert the battery and its been OK for the day so far. Probably not recommended by the makers but if you've tried everything else here maybe this will work for you too.
这个答案有帮助吗?
得分 1
1条评论:
I'm using mine for 2 months. I've tried all of the above with no result, your advice worked for a few minutes, than it stopped again. I'd add just to make it clear to anyone who finds this thread, that it's the mod you have to insert a charger to, when it's empty. The batteries are charged for me, I'm using an external charger for that because in the past vapes of different kinds broke for me, the charger cable's metal plug thingy came out and I was advised not to use a cable to charge, but an external charger, so this is what I do . I've tried again, this time the Smok text appeared on the screen and that the battery is charged 100% (there was no battery inside). Third time is a charm, it stayed on this time, but it happened again and again, and after a few times it stopped reacting totally. Black screen. As I've read on Smok's website I may need a firmware update so I've reached out to them via email on support@smoktech.com, and the website I purchased it from if they can replace it. Now we wait..
完成的
添加一条评论
I followed your instructions Craig and surprisingly, it worked first time!! You is the best
这个答案有帮助吗?
得分 0
1条评论:
Will the G priv 4 work without Batteries at all? Just bought mine, charged it and NOTHING
完成的
添加一条评论
I purchased the H Priv 2 about a month ago. The first one worked about a week and the screen died. It would fire, but no screen, it wasn't in stealth mode. The company I purchased it from replaced it. So great, grabbed new, freshly charged batteries, popped them in, vaped on and off for about 3 days. One day, it just wouldn't turn on. Doubled check batteries in another mode, fine. Bought new batteries, charged them (I always charge externally) and still nothing. I'm so irritated! I contacted the company and demanded a refund. I will never buy another smok product!
这个答案有帮助吗?
得分 0
添加一条评论
Thank Craig, Followed your advise and it worked, the only thing I would add to your advise is that when you remove the batteries and press the big and the small buttons at the same time, keep them pressed while you re inserting the batteries, thn when you finish re inserting the battery then press 5 times.
这个答案有帮助吗?
得分 0
添加一条评论
Brilliant. Thanks sami zeidan, you method worked… yay.
这个答案有帮助吗?
得分 0
添加一条评论
Yes remove the batteries wait at least a minute. Make sure the batteries are fully charged hold both buttons, reinsert the batteries and if needed hit the fire key 5 times for restart. Viola!? Has worked for me in the past, must be the way to reset.
这个答案有帮助吗?
得分 0
1条评论:
Yo lad just bought g priv 3 did soft ware update and my ecig just turned off and won’t turn back on do u bye anychance know why
完成的
添加一条评论
Hey guys u need some help iv just bought the g priv 3 and just done software update now it won’t turn on could u please help
这个答案有帮助吗?
得分 0
添加一条评论
There is obviously something wrong with the priv. I am getting the same issue. Mine is 2 months old. Not been dropped. Smok is definitely crap. I am moving on to something else. And you should too
这个答案有帮助吗?
得分 0
添加一条评论
I had similar issues and had to push in the bottom (I think it gets loose if you drop) when pressing the 5 times. Has stayed on since.
这个答案有帮助吗?
得分 0
添加一条评论
Try checking if it charges when the battery door is open slightly. Hold the door shut with barely any pressure used a rubber bracelet like anti drug businesses and other places give out and it worked perfect lol maybe use a old school I <3 B××bies bracelet for some style all jokes aside i think the metal hinge inside needs tweaked a bit that or the metal connections on each end the battery need tweaked for less pressure so the batteries arent pushing against the got dang doorflap... P.s when u close the doorflap slide the sliding lock/release all the way locked so that doesnt start to happen in the first place
这个答案有帮助吗?
得分 0
添加一条评论
Just bought my G-PRIV4 it will not cut on it shows it’s charging but won’t cut on what to do
这个答案有帮助吗?
得分 0
添加一条评论
My G-Priv would not power up, even after pressing button 5 times and fresh batteries.
I took a cotton swap with alcohol and cleaned the contacts of the G-Priv battery compartment. I even cleaned off both ends of each battery.
That did the trick. Works fine now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Nolson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 78
总计 74,985
