when installing new battery the horn sounds. how to stop this?
As soon as the system gets electricity, the horn sounds in an off and on pattern. How can I stop this and install the battery. Alternatively, where is the horn wire to disconnect it?
Answering my own question: Hook up the battery, then use the remote (car alarm button) to turn off the horn.
这个答案有帮助吗?
What if you don't have a key fob
If the beeping persists because your key fob does not work or has a low battery itself, endure the beep until you can start the engine of your vehicle.
这个答案有帮助吗?
Even when I get the car running thorn keeps beeping! Now what?
Start the car, put in reverse, drive and shut off the engine.
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 48
总计 26,756
2条评论
I am putting new battery in car . When i connect horn goes off won't
由 Bibus William 完成的
Check if you are connecting the correct battery terminals.
由 charles shungu mutototwa 完成的
