跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
20 个问题 查看全部
iPhone 7 Plus Boot Loop
Hi. My iPhone 7 Plus Keeps rebooting. Boot loop. It Turns on to white apple logo and then shuts off and then turns back on. Keeps doing that repeatedly. I've already tried a restore from my computer and it resets and shows the reset bar but then comes back to the reboot screen. Please Help. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
4条评论
i got this issue its two way one is disconnect the front camera seconed disconnect the home button
完成的
thanks for the advice, worked wonders.
完成的
I'm having the same issue recently restored an iPhone 7 plus and the home home button flex cable must have been damaged i the process is their any way around this.any way to get another functional home button? and advice is much appreciated.
完成的
Look up JC home button. There are 3 or 4 versions. So get the latest one.
完成的
添加一条评论
8个答案
最有帮助的答案
In my experience the most common cause of a bootloop an an iPhone 7 is the Audio IC chip… or rather the lack thereof. This chip will loose some of its solder joints similar to how the touch IC would on the iPhone 6 plus.
Here are some images showing where it is and how to get to it.
The only real way to fix it is to remove this chip, re-ball, and re-solder it back. This does come with some risk and should only be done by an experienced professional.
Also, with some of the later updates of iOS, most iPhones will boot up showing only a black or white screen before showing an Apple logo. This alone doesn’t indicate any kind of issue with your phone.
这个答案有帮助吗?
得分 2
1条评论:
i done it ans was very good solution. with thankful
完成的
添加一条评论
I have not worked on the 7 plus yet but have had this issue with several of the 6 plus iphones...both of which require board level repair. 1st repair is to replace the Tristar (U2) charging IC Chip and 2nd is to verify proper voltage on NAND (Hard Drive) (Reball has helped).
It could be a software issue as well I imagine but if you are not able to restore, have restored with same issue, or get an error message on Itunes, I think your best bet is to take it to a good repair shop or to Apple if under warranty.
这个答案有帮助吗?
得分 1
1条评论:
It did turn on and boot to the setup screen once yesterday but the home button wasn't working so I couldn't set it up and turned it off to restart it. It started doing it again.
完成的
添加一条评论
on iOS 11 you don't test out screens.... replace everything on the lcd and install the new lcd with every screws, close up the phone. then turn on.
note: there are many diff kinds of screens that doesn't work with iOS 11.
if problem continues, check every wiring on the new lcd.... or try putting everything on old screen or working gem screen...
in some cases i hard reset 3 times and plug in the charger.
这个答案有帮助吗?
得分 1
1条评论:
Do you know a reliable supplier that has compatible screens?
完成的
添加一条评论
Reinstall the screen with the front camera detached and see if that kicks it out of the loop. The cameras are very fragile and often times when the phone gets hot, It damages the camera and causes that to enter boot loop. If this works, simply replacing the front camera will usually fix the issue.
这个答案有帮助吗?
得分 1
添加一条评论
Please try to use 3uTools to restore your device. Hope it would work for you.
这个答案有帮助吗?
得分 0
添加一条评论
Hi there try this, Press and hold the Power button and Volume Down button simultaneously until you see the Connect to iTunes screen. Do not release the buttons when you see the Apple logo because you will need to enter recovery mode first. You will then be prompted with the option to Restore or Update. When holding the buttons down it should take around the 20 second mark.
这个答案有帮助吗?
得分 0
1条评论:
I tried it but it doesn’t do anything
完成的
添加一条评论
Fix iPhone Stuck In Boot Loop On Apple Logo without losing your files https://youtu.be/0XGMFmHLFCw
这个答案有帮助吗?
得分 0
添加一条评论
To fix iPhone boot loop, this post will be of assistance. I have solved the same problem with the method from it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
xsulemanhanifx 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 28
总计 23,182
