跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Compass and Auto-Rotate malfunction after screen replacement
Hey there,
Yesterday replaced my cracked screen and all went well except one thing, when I boot for the first time noticed that the screen won't "raise to wake" and I started searching for solutions, found out that my motion sensor won't work (auto rotate doesn't work) and my compass is stuck at 0º.
I am writing to you in hope that you have a solution, all the other iPhone functions like front facing camera and proximity sensor are working fine. Sporadically the screen wakes when I lift my phone but it happens 1 time in 100..
Help is much appreciated
Artur Amaral
Update (07/31/2017)
Update (08/02/2017)
SOLVED
Checked if the flex shield was the problem and the rotation was working with it, when I was closing the phone installed the battery conector shield and that was the problem, without the shield the compass is working fine!
Thank you for your help
Update (08/29/2017)
Problems have returned..
Shacky icons all the time, shaky video capturing, leveller always moving, raise to wake working inconsistently
After a hard reboot all is okay.. few minutes later the problem returns..
https://drive.google.com/file/d/0BwUc3GV...
These are some videos explaining what is happening, I'm getting tired of this problem..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
最有帮助的答案
I would take it back apart and check all of your connections I seems that your accelerometer isn't working. Its soldered on the motherboard so it can't be unplugged, but if some of your cables are loose or bent it can cause some strange problems like this.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your answer, already done that, checked all connections and all seems fine.. even changed the power button flex and the front camera flex with brand new.. things to do is clean the motherboard with alcohol and check if this problem happens with no screws holding the plate that secures all the flex in place..
I don't know if the motherboard can be magnetised or if there is a problem with the screws being magnetised.. I used a magnetic screw driver..
完成的
I use magnetic screw drivers every day on them and never had a problem. Also one more thing I would check is that the shield that all the connectors are under is not on too tight. I've also seen this cause some problems. This is a strange problem though.
完成的
添加一条评论
Try just plugging in the cables without the bracket, and leave the home button and proximity cables unplugged. If it still doesn’t work, try the old screen. Maybe it has a manufacturing defect.
这个答案有帮助吗?
得分 1
3条评论:
Already tried a complete new screen with all the sensores new and had no luck..
完成的
No, with the old screen. The original, OEM screen can sometimes solve problems because the aftermarket ones aren’t as high quality as they say they are.
完成的
This problem started with the original screen
完成的
添加一条评论
I have seen this in some phones, they often have a non magnitised Screw/Standoff near compass, Also was the heat sheild stored near magnets and perhaps magnetised?
这个答案有帮助吗?
得分 0
1条评论:
I don't know if there is a non magnetised but yes, the shield can be magnetised by the screw driver. Without it the compass is working fine
完成的
添加一条评论
Update (08/29/2017)
这个答案有帮助吗?
得分 0
添加一条评论
I replaced my iPhone 6s screen a couple of months ago with one supplied by ifixit. I’ve had intermittent shaky icons since and today the screen rotate no longer works. I’m not that impressed with the new screen (colours and brightness didn’t seem accurate, and I’ve had to turn off the 3D Touch because the screen sensitivity is rubbish). As I said, it’s been 2 months since the repair with no obvious issues besides these occasional shaking episodes, so I can’t even say if the two are related.
这个答案有帮助吗?
得分 0
1条评论:
I wouldn't think that auto rotate is related to the screen as it uses an accelerometer to detect the orientation, and by shaking do you mean like if you were wanting to uninstall an app shaking?
完成的
添加一条评论
添加你的答案
Artur Amaral 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 5,229
