跳转到主内容
苹果推出的面向个人消费者以及教育市场的笔记本电脑产品线。 iBook 系列包括 iBook G3 Clamshell,G3 12寸,G3 14寸,G4 12寸,以及G4 14寸。
Problems in booting process with the display
Hello,
I have an Apple iBook, it has a problem that when I switch it on, it boots, but it starts to display different colors on the screen and can't display the desk top files.
What could be the problem??
Thank you,
Sharpline
I'm from Uganda
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like a problem with the video. Does it change at all when you move the lid? One test would be to try using an external monitor. If that works then the problem is likely the video cable or the display controller built into the LCD panel.
I had a MacBook Air once where the hinge cracked and cut into the video cable which ran nearby. It would only show blue colors. But it worked with an external display.
这个答案有帮助吗?
得分 3
1条评论:
thank you so much rokin , i will try it
完成的
添加一条评论
添加你的答案
sharpline 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41
