跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
163 个问题 查看全部
How can I properly re-insert the hinges?
My GBA SP can flip open, staying about 150 degrees. After I got a new shell, the screen part began to feel more heavy (loose and floppy to say the most) and doesn't make that *click* sound whenever I open or close my gameboy. I figured it would be the hinges so I reopened my handheld and disassembled most of the parts to get to them. I fixed the hinges, but the screen half still flops; bypassing the 150 degree angle to 180 and still doesn't do the clicking. I've done this numbers of times fixing them with no luck. I don't understand where the problem lies whether I improperly repositioned the hinges or that they were very worn conditioned. :\
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I never dissassembled one, but, you can try to rotate the hinges (if you can) 180 degrees, maybe is an issue of just tightening the screws a little more. Also could be the new shell, specially if its a cheapo one, are poor quality build, and most of the time will wobble and cause the problem, or if it's used, could be broken as well...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
braxtongsp1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 2,818
