Display Issue Problem Isolation
So I just did a logic board replacement on my MacBook Pro (13" Mid 2012) because I had previously (this was my best theory) over worked my gpu. The symtpoms pre-logic board replacement were that it ran fine until it didn't and it crashed with chaotic horizontal lines across the display and would promptly restart. Based on these symptoms I researched and found I had most likely damaged my gpu which I can confirm is likely as I was at the time unknowingly putting a lot of stress on my computer's graphics capabilities.
So, the logic board switched out well enough and my computer no longer appears to crash with the aforementioned display/gpu issues, however, my internal display no longer works. HOWEVER, the external display works fine and my computer does not crash anymore like it was.
-I can shine a light through the back and only the apple logo appears. (while on)
-My display is still found by my computer under devices and the graphics/displays listing under system information.
-my camera at the top of my display still works also
So I wanted to get a bit of assurance that a display replacement would end my troubles once and for all. Any input?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
