跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Touch screen problems after replacing LCD Assembly
I had a customer bring me an iPhone 5C with a cracked screen. I replaced the LCD Assembly which you know includes the LCD and the digitizer. A couple of days after giving it back to her, she started having issues with the touch not responding and by the 3rd or 4th day it quit working completely. I thought it might be the assembly I bought, so I returned the assembly and had them replace it. The next one did the same thing.
I got the assembly from Amazon. By Generic, sold by Select US and shipped by Amazon. I've always had very good luck with this combo, but things happen so I decided to try a different brand. It got good reviews. It doesn't work either.
I hooked the phone up to my computer and did a software update and reset it to factory but it still will not respond. Do you think all three assemblies are bad, or do you think there's a motherboard problem? I doubt it's a software issue because I reset it to factory.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Maybe try cleaning the digitizer connections and check to see if they look damaged at all. Can clean carefully with alcohol, and make sure there is no debris that could have interfered with the connection.
这个答案有帮助吗?
得分 0
1条评论:
I appreciate your response but I already tried these. I put the motherboard under my microscope and the screen connectors and they look fine, so I cleaned them with alcohol before putting it back together. Still doesn't work. I did some Googling and saw some people with touch problems and after replacing the digitizer they had the same problem. Since I was able to restore the phone to factory wiping out everything, I'm able to rule out software conflicts. I'm thinking it's a motherboard issue. Thanks for trying!
完成的
添加一条评论
添加你的答案
mcr4u2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 116
