跳转到主内容
于2016年3月上市。型号 SM-G930V。
Why can't I make Emergency Calls (Or anything radio related)?
There's a lot of things going on with this phone, but right now I just want to figure out which part of the hardware is causing the problem.
So the phone couldn't do anything radio related, basically radio is turned off and cannot be turned on. Can't make or receive calls/text messages and if I go and scan for available network operators it will just say "Error while searching for networks"
At first I thought it was the SIM reader that's failing, since every SIM I throw at it just shows no service what so ever.
But the odd thing is that contact list is still being read and there is no notification telling me that I'm in Emergency call only mode.
And whenever I actually make an emergency call, a loading window just pops up and saying "Turning on radio". It will go on for a moment and the dialing would just hangs itself up.
If anybody can identify the issue and give me an idea of the repair cost, it will be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Does the phone display an IMEI under Settings > About Phone > Status? Hopefully baseband is not showing unknown as well.
这个答案有帮助吗?
得分 1
3条评论:
Both the IMEI and the Baseband version are showing correctly.
完成的
Did you ever solve this issue?
完成的
No I had not same problem
完成的
添加一条评论
添加你的答案
Peidong Lin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,385
