跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
CPU Upgrade, Why won't it now boot?
Help!
This is what happened to me and what I have done so far.
iMac 2013 27" 3.5GHz Nvidia GT780M 4GB (This may or may not be important)
So the hinge failed on this machine and, knowing my way around the iMac and other machines, I decided to change it myself. Having purchased a new hinge and the required strips to reseal the machine once I'd finished I proceeded with caution.
Everything went smoothly.
New hinge in place I thought - well whilst I've got it stripped downs so far, I may as well replace the thermal paste with some Arctic Silver 5. So I took the heat sink off, cleaned it up and reapplied.
On this model you have to put the CPU in the socket put the 'gunk' on. Put the heat sink on and then invert the whole logic board to insert the screws and spring from underneath.
Disaster! The CPU slipped and I wound up crushing the edge of the chip!
Don't panic, stiff upper lip and all, lets get a new CPU before my wife finds out.
Amazon to the rescue. Now I found this thread and looking at the costs and delivery times I purchased the 4790 (Not the K) instead of the 4771 that was shipped in the machine.
Put it in and reassembled. Put in the power cable - 1 light. Pressed the start - 2 lights ..... ..... ..... ..... .....
I understand it the LEDs are as follows:
LED 1. Trickle power
LED 2. Start button pressed - Main power on
LED 3. GPU found
LED 4. LCD found
So, I draw the conclusion that the mother board is damaged. (Seems logical to me). Ebay to the rescue. 4 days later a new mother board arrives with no CPU. i've just spent the afternoon switching the motherboards and CPU.
Exactly the same result as the old logic board. So maybe original the logic board is not damaged after all. Now I have (apparently) 2 functioning logic boards and 1 CPU (4790) and they don't want to play.
Can anyone shed light on this?
In total I'm down over £600 and still don't have a working machine. Worst I don't know why.
Trying to predict the questions that may come.
Light 1 on when power cable connected
Light 2 comes on
Fan spin up
Light 2 goes out
Fan stop
Light 2 comes on
Fans start
HD spins up
Fan spins faster
Fan reaches take off speed......
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your systems specs: iMac 27" 3.5 GHz i7 (Late 2013) - CPU Apple used in this model is a I7-4771
完成的
添加一条评论
1个答案
已选择的解决方案
Ouch! Sounds like you got the wrong CPU here. You need an Intel i7-4771 the i7-4790 won't work as the EFI doesn't know about it! (newer). The newer 'Thin Series' EFI's seem to have the chip series coded in them as well as the TPD. So you can't jump up to a newer version of the chip (assuming the chip will fit the socket correctly).
Sorry to say Apple offered an extended warranty on the hinge problem so you could have saved your self a bit of grief here ;-{
Apple Offering Refunds to Customers Who Paid for iMac Hinge Repairs as well as offered a free repair.
这个答案有帮助吗?
得分 2
2条评论:
Hey Dan,
Thanks for the response.
I have exchanged processors in the past, in my xServes, with no issues. So it didn't even cross my mind that the CPU wouldn't work the specs are so similar.
I have arranged for the new logic board to be returned and the 4790 i7 to be returned and got a 4771 on order now.
As to the hinge problem...... Grrrrrrrrrrr *!&$!&$^!
The socket on both of these chips is the 1150 and it fitted perfectly. I'm shocked that the EFI won't let it boot. I called the guy who sold the logic board and he also wondered if the logic board wouldn't work with anything faster than 3.5 (The max ever put on that board.)
Hey ho. Normally it shouldn't have been a problem, but I messed up.
完成的
@titaniumjones - Sorry guy ;-{
The older (2011 and older) systems allowed more CPU choices as long as the TDP & power wattage was within the systems ability to support.
Both of these chips are Haswell's and are very close to being the same. The base clock is a little faster on the newer chip but that shouldn't be enough not to at least run. Only the ID string is different between the series.
I knew the sockets were the same, sometimes I add a bit more for the others that also read the post so they get the full story as there is a 1150v3 socket which is not the same.
完成的
添加一条评论
添加你的答案
Simon Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 981
