跳转到主内容
加入维修社区 - 创建账户
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
Why isn't my s6 showing any sign of life?
My phone's recent apps and back buttons stop functioning. Eventually they came back on and only the recent apps button worked. After a while the phone was on the charger one night and when i turned it on, it was saying dm-verity verification failed/need to check drk first. Now the phone is completely dead when charging or not, the phone has no led indicators or anything. I have noticed that when plugged in the battery unusually heats up. Could it be a battery problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Have you tried doing a soft reset on the device? If that does not give you any signs of life, try to put the phone into its Boot Menu by simultaneously pressing the home button, volume up, and power button. If the phone enters the Boot Menu, then try clearing the cache and rebooting it. If the phone does not go into the Boot Menu, then the OS may be corrupt on the device.
If it does, there may be some further hardware issue going on with the device as your buttons are attached to your charging port. Last resort, try wirelessly charging the device. If it powers on, then you know there is an issue with the charge port.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your reply Jaz, I unfortunately dont have a wireless charger. However, neither soft or hard boot button combinations allow the phone to come back to life.
完成的
添加一条评论
添加你的答案
Jon Baboolal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 302
