跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone still not turning on after battery and change port replacement
I have a phone that would power on and show the apple logo but would turn off right away, after replacing the battery and change port it now is ether shows charging or wont turn on at all.
any idea on what this will be and how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your symptoms sound a lot like the Charging IC(s). I have repaired this issue several times and as recently as yesterday successfully. I would start by replacing the U2 (Tristar IC) chip first and should fix your issue. If not, move onto the Tigress IC that is right next to it.
I would add screenshot of chip location but I'm not sure what model Iphone you are referring to. Google search U2 and Tigress IC chip replacement and see if the symptoms match what you are experiencing and get back with me if you need more information or further troubleshooting steps on measuring voltages at battery connection Flex and Caps around these 2 IC's.
Good luck!
这个答案有帮助吗?
得分 3
添加一条评论
Have you made sure all connectors are plugged in? Especially the LCD connectors?
这个答案有帮助吗?
得分 0
1条评论:
Being that I'm a tech, I know how to put a phone together, if a needed bull crap response like ths I wouldn't have asked ifixit I would have watched a repair video. Thanks, but no thanks
完成的
添加一条评论
添加你的答案
Erin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 182
