跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for full size headphones that encompass the entire ear, also known as circumaural headphones.
Audio Static exposed wire.
I have a 6 year old set or urbanear headphones and I get an unacceptable amount of static when I use them. I opened one side of the speaker and I can see that there are two wires going to the speaker itself. One has insulation and the other does not. If the uninsulated wire touched the contact (solder point) of the insulated wire could this be a cause for the static I'm hearing? I have a picture below, I hope that can clear up any confusion, I'm not very experienced in repair, I apologize if I have used wrong terminology.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I love urbanears! great headphones. Okay, so the static sound you might be hearing could be the wires not being protected from electrostatic, which is common with electric guitar pickups having a "buzzy" sound when played. I recommend wrapping the exposed wire with electrostatic shielding. Link:[http://| https://www.amazon.com/Copper-Tape-Shiel...] . That might do it.
-Toby
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jak Davidson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 271
