跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone doesn't chage after screen replacement
i replaced the screen. iPhone is working fine but phone doesn't charge even after keeping it connected to the charger.
It is loosing the charge instead.
I checked charging port flex and changed the battery too. None of the troubleshooting worked.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
try to change the charging port,if doesn't work maybe during your screen replacement you accidentally damaged you motherboard and cause short circuit,try to find the charging circuit and check the circuit
这个答案有帮助吗?
得分 0
1条评论:
I already checked the charging port. It didn't solve the issue.
Is there any way to check the charging port circuit and fix if that's the issue?
I would appreciate if there is any guide to do it.
完成的
添加一条评论
添加你的答案
acc asd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 51
