跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
No Sound On Facetime After Screen Replacement - Calls Work Fine
Hi
As stated in the title, did a screen replacement on an iPhone 5 (I have a business and have done hundreds before without an issue) , now the customer is telling me that there is no sound via FaceTime , but sound works fine on all other calls and all other functions work fine.
Recording a voice memo and playing it back also works perfectly.
Any idea what I've done here? I can't figure it out and would appreciate all advice :)
Thanks
Alex
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There are 3 microphones on the iPhone and FaceTime uses a different microphone than phone calls or voice memos.
FaceTime uses the Top-Front microphone, which is included in the FCAM flex. When you replaced the screen, did it come with the FCAM flex pre-installed or did you migrate it from the original screen?
If you migrated it, you may have misaligned the microphone. Also double check the connector to insure there is no debris or damaged pins.
If the screen came with the microphone pre-installed, it may be defective. You can always try the original one instead.
这个答案有帮助吗?
得分 1
2条评论:
Thanks, I moved the front flex cable from the old screen , will get the phone back and examine it , then report back!
完成的
Yes, please do!
完成的
添加一条评论
Yes, check the connectors to make sure they are plugged in or if already plugged in, plugged in correctly and are snug. You also may have accidentally ripped a cable by accident.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex S 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 100
