跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Proximity sensor doesn't work even after screen and flex replacement
Hello.
I'll try to tell you my "story" briefly.
1 month ago I went abroad and bought me a new iPhone 6s plus LCD.
came home, replaced the screen - The screen doesn't dim at all while calling...
I was thinking what went wrong... my proximity sensor DID work!
Fortunately I had a new proximity sensor flex cable (that also comes with front camera and all...) and replaced to that new flex cable - STILL NOT WORKING!
Tried to seek online for solutions and and I figured out that probably the screen was doing the problem and its a fault. But I can not go to the store and replace it because it was abroad, so I tried all the solutions online to fix the proximity sensor eyepiece in the screen.
Tried to scrap the color and recolor it with a black pen and do a little holes - STILL DID NOT WORK.
This time I gave up and went to buy a new screen, replaced it to the new screen - AND STILL DON'T WORK!!
After that I tried to do an hard reset and reset all settings - STILL DON'T WORK!
I don't know what to do... I am trying to see if the the proximity sensor bracket (the transparent little piece that holds that) doing the problem because he was painted a little bit in black while I was painting the screen eyepiece... maybe I will replace it?
What do you think I need to do?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm not sure what your skill set is, but I have had this issue in the past after working on a phone and this video really helped. It is most likely not your actual sensor and is a component on the Mother (Logic) Board.
A skilled Micro Soldering repair shop could do this for you if you could not.
Hope this helps!
https://youtu.be/TOCyk6gTIy4
这个答案有帮助吗?
得分 0
2条评论:
Ok thank you, I'll check it...
It's my last hope :(
完成的
Let me know, hope it does :)
完成的
添加一条评论
添加你的答案
liorgolan29 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 287
