跳转到主内容
修复你的物品
维修的权力
商店
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
648 个问题 查看全部
Phone won't switch on
Phone won't turn on even with forced reset
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
can you try a new or a friends S4 battery? If you plug in the charger and can see the battery charging or the battery logo it may be the power button. Galaxy S4 have a power button that will need to be soldered on in order to replace the Button. the only way to test the button is by opening it up and testing the button itself for continuity on the connectors. If the charging port is bad and not charging the battery it may not turn the phone on. try another charging cable also just to rule it out. hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Beverley McMahon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 39
