My charger will not fit into the port. How can I fix the charging port
The chargers will not go in. I think the charging port needs repair. How can this be done on LG Optimus L90
Is the port bent? Are one of the prongs inside the port popped up? If either one of those is a yes. then you need to replace the port on the actual phone. If none of those is thne problem. Try getting a new charger and see if that works. Or try putting it in on an angle.
Goodluck!
-JR
这个答案有帮助吗?
Yes the problem is the prongs are messed up. I tried with different chargers but nothing seems to work. Can you show me how to replace the charging port?
Thanks
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 87
Thanks
由 Abhi Shah 完成的
