跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone stuck in restoring
Tried to update phone's OS from 8.2.3(or something) to 10.2.3 only to have it stuck with the apple logo and the progress bar. As it reaches about 70 percent of the bar, it stops moving forward and eventually restarts.
I put it into DFU mode, tried updating with another computer and eventually it worked. Unfortunately, I'm now trying to revert back to the backup I had saved of the prior OS only to be stuck with the same problem with the progress bar and the apple logo as it reboots endlessly as the bar reaches about 70% and stops.
Am glad to provide any other helpful info.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Are you trying to restore the whole IOS system or just your files?
And you didn't by any chance happen to save your SSH blob? Unless you have, there is no way to downgrade your phone as Apple has stopped signing older versions of IOS.
这个答案有帮助吗?
得分 0
2条评论:
I certainly wish I could restore the whole OS. I thought I could do so if it was from a backup. The files aren't as much of a matter, but still I'm annoyed that the phone gets stuck in a reboot loop.
Unfortunately not. Wasn't even aware of such things before updating. It turned out to be such a nuisance I felt like smashing the bloody phone, especially since it already had some problems and now they've been worsened by the update. Ah, well.
完成的
I guess you know for next time!
(If the answer helped you, id appreciate if you could mark it as there chosen answer).
完成的
添加一条评论
Not 100% sure this will work for you as it did me, but I heated up the phone a bit...about 80c to the back where it was very warm to touch and it completed with no errors. I eventually removed and reballed the NAND and issue went away all together.
这个答案有帮助吗?
得分 0
1条评论:
Huh. Sounds like a rather unorthodox solution, but I might give it a try. I do wonder, though, how does one come up with these ideas for fixing a problem like this?
完成的
添加一条评论
添加你的答案
Smeargle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 9
总计 157
