跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1051 个问题 查看全部
Why Is my customers iPhone SE Not charging past 8%?
So i replace the screen everything was fine... and now for some reason the phone wont charge past 8% ive tried a new dock and multiple batteries and still a no go. He swears he has been using a Apple charger, but with customers sometimes you never know. Hoping this is fixable please and thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
It is possible you pried off or partially dislodged the filter on the TIGRIS_TO_BATTERY_SWI line. That line send the charge state of the battery (as well as other info) to the CPU. This is how the charge circuit determines when to charge or not.
The filter is a small SMD component next to the battery connector on the logic board. It is the second one from the bottom (there are four in total). This requires a micro-soldering repair.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Alain Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 483
