跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
replacing front brake rotors
how do I remove the old rotors?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
While it's a different car, the process will be pretty much the same, so check out the guide on this device page:
Device Page
The main differences will be the sizes of the tools, and many times the rotor has two phillips head screws holding it to the hub. Those tend to be very difficult to remove unless you have an IMPACT DRIVER SET like the one in the link. Those you can usually pick up at a local auto parts store for less than $20.
Photo the process and make a guide specific to the car for it, and if you get stuck, feel free to ask.
这个答案有帮助吗?
得分 2
1条评论:
Adding to that, you can usually borrow these tools from Autozone
完成的
添加一条评论
添加你的答案
Sean 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,910
