跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Backlight / screen problem
MacBook Pro a1502 - 2015
I have a weird problem.
I replaced a logic board on a MacBook a1502. Year 2015. Problem. Was liquid spill, on the bad board everything would work when plugged in , but it would not work on the battery.
I replaced the logic board , and everything was fine. Few days later Customer dropped laptop while it was on from sofa. Nothing was fiscally broken but the screen went black ,.
It works on a external monitor through HDMI ,
The backlight of the LCD actually comes on, but it only comes on after boot, but no display. During boot cannot see apple logo even if I put light to it.
So, to check if was board or screen I took the old board which was still working ,but only plugged to power, and same problem happened. So I thought screen is bad.
Order new screen assembly, installed it, now I get no backlight at all , I can see apple.logo during boot, the desktop icons and everything but no backlight at all..
Took the old board, installed it ,same problem.
This is driving me nuts, could it be that the bad screen had some kind of short and it actually damaged both boards ?
Or maybe the new screen I got, is a factory defective unit ?
Thanks for any suggestions
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There is a possibility the LCD you received was defective, its is however much more likely that the (I think 2 off the top of my head) cables between the LCD and the Motherboard got pinched or yanked in a way that weakened them enough that the fall the laptop experienced 'finished the job' so to speak.
I would recommend ordering a set of LCD/Backlight cables (they'll probably be pulled out of another laptop, they are exceedingly difficult to find new) and testing the new MB with the new cables and the old LCD.
P.S.
This info comes from going through the same extremely frustrating experience you're experiencing, only I ordered 2x new LCDs and 2x new cable sets before I got it over with
这个答案有帮助吗?
得分 1
1条评论:
Thanks for your reply, the problem was actually a bad new LCD I received. I sent it back and order a new one and it worked. This was actually the first time I have received a bad brand new LCD.
完成的
添加一条评论
I am Not a Computer Repair Specialist, yet anyways lol but with the help of this site, google, & youtube, I'm sure that i will be soon enough, But aside from that I am a Certified Electrician and just reading your the Synopsis of your problem, I am almost 100% positive that your Diagnosis is a Electrical Short, Find the Short and Replace that component, wire, or connector and your problem is Solved, Good luck, Hope you figure it out, and when you do I would greatly appreciate if you would be able to inform me on what is that you find out, Problem & Solution, Thanks
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply. the problem was actually a defective LCD I received.
完成的
添加一条评论
添加你的答案
Daniel Matos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 3,252
