cant turn on after replacing battery
I replaced the battery in my HTC 1m9 and its charging but I can't turn it on.
What do you see from the phone at the moment when you plug the charger in?
You should see at least:
An orange light at the top, a charging logo displayed at the middle, hopefully with a percentage sign under the battery as well.
What was wrong with the phone before you replaced the battery? Was it draining too fast, not charging then you couldn't get it to charge once it went flat?
这个答案有帮助吗?
What if you do not see anything. The haptic screen feedback works and so do the sounds but I cannot see anything on the screen
Did you ever fix your phone? Same issue. Replaced bad battery and won’t turn on. Only get charging icon on screen when plugged in. Buttons on side won’t turn phone on. Assuming I fried the motherboard when changing battery
这个答案有帮助吗?
Same Issue: definitely charges, and the screen comes on, i cant test if volume up down or on switch are 'working' but I cant see any physical damage. Phone was draining fast and turning off near 15% full with old battery. new battery lights up the amber light, and the screen lights and displays the recharge rate when plugged in. Windows isnt recognizing phone, but I'm not sure if that is abnormal if it is plugged in and not turned on. I tried holding all 3 buttons but Im not seeing a change but I will try again whatever is suggested.
这个答案有帮助吗?
Hi. I have problem with my HTC 10. Did you fix yours?
The battery of my HTC 10 was in poor condition. The charge was running out quickly. When the battery dropped below 40 percent, the phone was heating up and closing. Recently, the phone heated up again and turned off. I put it in to charger again, but the phone wasn't on. Upon this, I replaced the battery with original one but phone is not turning on and not charging. How can i fix it ? Charger port and cable in good condition. i tried diffrent charger and cable. Still, not working.
Pls help me. Thank you.
hi i just replaced battery in mine and i have no power at all not even charging light
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,062
