跳转到主内容
任天堂于 2011 年 2 月发布的首款 3DS 掌上设备,型号为 CTR-001。
How to improve the connection at the circle pad zif socket?
In my initial teardown of a 3DS, I inadvertently pried off the plastic tab that closes the zif connector for my circle pad. Now, the connection is not strong enough to reliably send readings to the console, leading to erratic behavior. Is there a way to remedy this situation without replacing the motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Measure and replace the ZIF connector on the board. You will need to solder.
After eyeballing photos (I no longer own a 3DS variant of any kind) one of these is likely your connector: https://www.digikey.com/products/en/conn...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marshall Sutton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 126
