跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
No display after battery replacement
A customer brought the device to me saying it needed a battery. Device showed no signs of life.
I replaced the battery. The logic board heated up but no picture. Also, i did this repair without removing the front panel assembly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Try another screen, known working charger battery?
Also does it detect via computer in iTunes in case of a no backlight issue?
完成的
I tried an authorized charging and nothing. I thought about trying another screen. I'll give them the option because they bought it from someone else so there's no telling what prior issues that it had.
完成的
But still no picture
完成的
添加一条评论
4个答案
I would suggest disconnecting the front panel assembly while replacing the battery. Then try booting your device up with the new battery. If it does not turn on or show signs of functionality, I would look into replacing the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe it gone in DRY mode try to connect with itunes... then unique option is restore
这个答案有帮助吗?
得分 0
添加一条评论
Do you notice this:"The logic board heated up ", what happened to it?
这个答案有帮助吗?
得分 0
添加一条评论
Yes the logic board did heat up quite a bit
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The Wizard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 98
