跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
iPhone 5c powers on but screen is white with vertical black lines.
Hello everyone, I have an IPhone 5c that seems to power on but screen remains white with vertical black lines, hope one of ya can help me with this :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Is the screen cracked in any way?
Have you dropped it?
Any pressure been applied to the screen?
The lines indicate that the lcd is damaged.
The top portion of the lcd underneath the glass is very fragile so possibly that has been damaged in some way.
Cheap enough to fix if your competent and not too expensive to get a repair shop to do it.
这个答案有帮助吗?
得分 0
5条评论:
Basically the phone was a hand me down from a close friend, The phone definitely seen some battle judging by scratches and dents on the plastic but the screen itself isn't cracked also I popped off the screws and carefully looked inside some components were pretty dusty and the small little white water damage indicator was red (I believe it's the water damage indicator)
完成的
Yeah that's the water damage indicator and if it's red it's definitely had some sort of liquid damage.
There is a possibility of corrosion on the connections between the logic board and the lcd ribbons.
Open it up and disconnect the battery, disconnect the lcd and check for corrosion.
Clean the connections with isopropyl alcohol and test.
If that doesn't work then the next step is to try a new screen.
完成的
Make sure to unplug battery first as well.
完成的
Will do, though will take me time to get a replacement screen if the cleaning doesn't work, any good places to source out a screen replacement in case. Also that alcohol solution won't damage any of the components or circuits?
完成的
Yeah 99% isopropyl alcohol is safe to use.
完成的
添加一条评论
Hello Pedro, the alcohol will not damage anything. Just apply it carefully in the areas where you see corrosion, you want to focus on the battery and lcd connectors in particular and may be a good idea to clean them either way as sometimes corrosion can not be seen without a microscope. A good place to source a new screen if required is iFxit(I am not sure if they have stock). If not you can google and will find many suppliers, I would stick with only high quality parts and do separate reviews on whoever you choose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pedro S. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 74
