跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
Mid 2011 iMac EFI Chip Swap Question
The motherboard on my imac went bad so I purchased a complete motherboard on ebay. Same model but an i7 processor rather than the i5. Except that when I got it I found out its EFI locked and it's a mid 2011 so the ram trick won't work. I have read through how to reprogram or clear the password on the chip but thinking it will be easier to just swap the unlocked chip on my old board to the new. Because it's the same model and the serial number on the old board is mine and it's trash i shouldn't have to do any programming that way right?
Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Happy to update I swapped the chip and it worked perfectly. With a hot air solder gun the process took about 5 min. My iMac is back up and running.
I would post pictures and video of the process but to your point, I don't want to encourage unethical EFI chip swaps.
这个答案有帮助吗?
得分 1
2条评论:
i have bought an old Imac with efi password. Can you post me some pictures to locate the chip. Thanks in advance.
完成的
Hi, can u tell me where the efi chip on the mid 2011 logic board is located? that would help me a lot! thnx
完成的
添加一条评论
最有帮助的答案
If its EFI locked you should return it to the seller and get your money back as it came from a stolen iMac!
Are you sure the main logic board is bad? Maybe it's only the graphics card which you could swap out with the other board to at least test. If it is then you could return the board and just get a replacement GPU card.
That would be cheaper and you would be doing the right thing here not rewarding a chop shop that handles stolen systems.
这个答案有帮助吗?
得分 1
2条评论:
I have already replaced the video card, power supply, RAM and the issue persists. Motherboard was a last resort. As I understand it the not for profit I purchased it from received the iMac as a donation and lost the password that came with it. I got the complete motherboard with video card and processor for $50 so I would not be returning it even if it didn't work at all as the other parts were worth the purchase price. I took a risk and I'm okay with that. They actually did disclose it was locked I just missed it in the description.
I get there are people out there stealing macs but by no means does that mean every locked mac is stolen. I do not believe there is anything unethical going on here and would take it to apple to unlock if I thought they would be helpful.
I don't really have much to lose so I will swap the chip and if it works great. If not I'm no worse off. The computer isn't worth spending a few hundred dollars to buy a new motherboard.
完成的
@zeerocool - David I hear you! The problem in todays world is you can't tell who is who! In an open forum as this I don't want to offer help to the thefts. Sadly that also effects honest folks as well.
As for your systems value you would be surprised it still has value!
Good Luck!
完成的
添加一条评论
添加你的答案
David Zabran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,057
