跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Apple iPhone 7 Plus - Logicboard dead?
Hello everybody,
I got an iPhone 7 Plus, which felt down from an carousel.
From this point on, the phone doesnt work anymore.
I replaced battery, LCD screen & dock connector, but I get the following reaction:
The logicboard gets very very hot but it the screen wont turn on and just keeps black.
It also cant be found on iTunes.
I can turn it on by Power-Button, but thats all I can do.
I only know by the temperature, that it turn on.
Maybe anyone of you have a suggestion for me, what I can try.
Best Regards
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
It needs looking at by a logic board specialist.
The heat indicates an electrical short somewhere on the logic board.
这个答案有帮助吗?
得分 1
4条评论:
Its not an original battery, maybe this causes the heat?
I also got the original battery, it smells like it lithium, maybe the old battery killed the logic board, is that possible?
完成的
No, it's not the lithium. I've seen this before, but I haven't found the answer
完成的
Thank you very much!
Do you got any suggestions I can do without an logic board specialist?
I tested it also with the old battery and I think it gets warms (normal temperature) but still wont show anything.
Do you know any logic board specialist in Germany?
Best Regards
完成的
Regarding lithium, its the same smell like when an iPhone battery gets opened.
完成的
添加一条评论
添加你的答案
iphone4s 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 770
