leak battery power becouse of weak signal
my phone got some water but it is still working only the problem is with the signal is so weak and it cause leak in battery power
I wouldn't pin your battery problems to weak signal strength, you've probably done more damage to the board and battery than you think.
Although, yes, weaker signals use more battery than stronger ones due to packet lose, I think yourbattery is damaged.
这个答案有帮助吗?
if I changed the battery then what about the signal ? I feel the main problem is the signal
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 167
