跳转到主内容
加入维修社区 - 创建账户
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
Samsung Galaxy Tab Pro SM-T900 Overheating
What could be possibly causing my tablet to overheat, usually while playing games?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
My tablet gets overheated whilw charging. It stops charging.
If charged, battery drains much faster.
完成的
What to do if my tablet overheats
完成的
添加一条评论
2个答案
最有帮助的答案
Currently staying in 40c ambient environment and this is my second TABPRO S, previous never had heating issues then I realised what I read about chrome... I use edge mainly but chrome for some things. On the new install I noticed very hot top right corner (I assume processor is there)... and then I remembered reading about chrome mullering battery’s and CPU useage...
I turned off the background activity for chrome and reduced sync to use two options that I actually benefit from...
In ''settings “Continue running background apps when Google Chrome is closed” and deactivate it... I sync bookmarks and browsing history only.
It worked immediately for me... TABPRO S no longer heating beyond expected.
这个答案有帮助吗?
得分 2
添加一条评论
The internals of a device goes a lot of programs to work so most of the time when the device has multiple tabs or apps open at once the device can heat up. Also if the storage is low then the device can slow down and that could make the device warm up faster. And lastly when the device is in use for a long time the Comonents in the device can also heat up. This can also happen when charging and playing or using the device. ( sorry for my bad English )
这个答案有帮助吗?
得分 0
4条评论:
How to get over it. I am told that battery need replacement. Will that be. If so, where do I get the battery in India.
完成的
where do I find repair shop in Delhi India.
完成的
Um you can try to oppen another device for the same type and take the battery
完成的
I am also hues a kid so I really don't know that much but try not to use the device for few days and see what happens
完成的
添加一条评论
添加你的答案
Marilyn Haynes 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 5,226
