跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
624 个问题 查看全部
epson l360 cant print legal paper
i'm trying to print some projects that requires a legal size paper. how ever epson l360 only prints in a4 or letter size paper. i tried to customize everything but still does not work. what should i do to print my project in legal size paper?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 31
9条评论
I looked around online (as I'm sure you did too) but didn't find anything promising. If the printer doesn't accept legal size paper it may not be (reasonably) possible to force it.
(I say reasonably because I'm sure there are all manor of Unreasonable ways we could try to do it. Changing the firmware/code is totally beyond me. And folding the paper to make it fit and changing the document accordingly would be asking for trouble. Plus it would work badly, if at all. Then you'd be troubleshooting a paper jam as well.)
Best of luck and I hope someone else has something better to suggest.
完成的
We cannot detect the epson printer
完成的
I have my problem. My printer is epson L360 .. now im printing a email and printer isa just printing half of the email lower part of the paper is blank .. how to solve this ? Please help me
完成的
How do scanner legal print l565
完成的
I cannot print legal on my Epson L210 printer, any solution? thanks
完成的
显示更多的4条评论
添加一条评论
3个答案
已选择的解决方案
go to www.epson.com.ph then click SUPPORT>PRINTER>INK TANK PRINTERS> L SERIES> Epson L360 > operating system dectected> DRIVERS> then installed any or both if applicable the Printer Driver for WIN 64 bit and Scanner Driver for winndows> restart your PC. DONE.
这个答案有帮助吗?
得分 46
37条评论:
Thank you! Problem solved!
完成的
完成的
been stressed for a week finding out a solution, i knew it!!! thanks to you. Godbless
完成的
it works!
Thank you very much God bless
完成的
how to print legal size on epson L360?
完成的
显示更多的32条评论
添加一条评论
Solved! (for me)
I have the same problem, I am using windows 10 and by then, the printer is using the default driver within the OS, thus, it recognized upon plug and play. I have configured the paper size to 8.5" by 13" but sill it prints in A4.
Solution: I located the mini DVD driver that came with the printed, installed it and then it solved the problem.
这个答案有帮助吗?
得分 2
2条评论:
thank you very much... great help indeed
完成的
What if the dvd driver is lost?
完成的
添加一条评论
Go to control panel→Hardware and Sound→device printers→open the properties of epson l360→advanced→change the driver to EPSON L360 SERIES..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Junape 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 156
过去 30 天: 740
总计 76,811
