跳转到主内容
An all-in-one inkjet printer, scanner, copier series by HP. Model number CX042A.
31 个问题 查看全部
Why is my ink carridge not moving after a paper jam.
My printer was working fine but then had a paper jam. Removed jam but printer is not aknowledging this and the print cartridges wont move even manually. Can anyone help please as can't afford a new one? thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
How can I overcome the problem?
完成的
添加一条评论
1个答案
最有帮助的答案
I'm not familiar with your printer, but I work with large format machines.
First off, It's important not to force the print carriage (the part that holds the print heads) as this could damage the belt that attaches to the motor or the motor itself.
As a first step, you can always turn both the printer and the computer all the way off and then back on. While the printer is off, unplug it and hold the power button for about 10 seconds. Not sure if it matters but I turn on the computer first, then the printer. That way I can make sure there is nothing in the print queue.
If that doesn't work, The manuals usually have troubleshooting for this kind of problem in the back section. There is usually something like a maintenance cartridge or other device that is keeping the motor engaged and will keep the print heads from being moved.
这个答案有帮助吗?
得分 1
2条评论:
I have done this but got no result
完成的
Should I open the printer ?
完成的
添加一条评论
添加你的答案
doddsarah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 14
总计 378
