跳转到主内容
加入维修社区 - 创建账户
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Older 21'5 late 2012 iMac will the newer retina 4k LCD work in it?
I'm using older iMac 21'5 late 2012, can I replace the screen with the newer retina LCD?
Please advise,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
No, unfortunately not. The main issue will be the logic board, which is only capable of outputting HD (1920 x 1080). so even if you could retrofit the display, there would be no way of getting the GPU to output to 4k resolutions.
But aside from that, the imbedded DisplayPort cable, the LCD port and the logic board port are all different between the models. The only similarity is the dimensional size of the machine unfortunately.
这个答案有帮助吗?
得分 3
添加一条评论
Sorry no the older 21.5" models use a different interface logic than the newer 4k models.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
coven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 358
