跳转到主内容
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 个问题 查看全部
after lcd and digitizer replacement, home button no worky
Home button was working fine before the repair, even with a severely shattered screen. New ifixit parts went in nice and smooth, everything work now except the home buttons. My digitizer and lcd cables are fully seated (no white lines) and locked down. Any ideas guys? Bad home button on new digitizer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Is there a way to electrically test the circuit that simulates what happens when the home button is pushed (i.e causing continuity between the two gold posts on the dock connector. By shorting out the two gold posts in the dock connector that should simulate pushing the home button (which does just that). If I short the gold posts together and dont get any home button "response", am I then to assume that my dock connector ribbon cable assy is faulty?
完成的
You can test the home button on the digitizer glass by using a multimeter and checking for contenuity while pressing the home button down.
You can also take the home button from the digitizer assembly and place it on the two connection points on the charging assembly and see if it responds there.
If you can't get it to work at all then the home button is faulty.
完成的
添加一条评论
1个答案
已选择的解决方案
You kinda answered your own question.
Either the home button is not aligned properly to the two gold contacts on the charging port home button connector or it's just faulty.
You can use the home button from the old screen but it requires realignment and may also need more adhesive for it to stick on properly without home button dipping in.
这个答案有帮助吗?
得分 1
1条评论:
I shorted out the two gold pins on the dock connecter with the ipad on, no home button "response" occured. Looking more like the dock connector is the culprit unless I'm missing something else to check. Thanks for all the pointers fellas!
完成的
添加一条评论
添加你的答案
john Scrivener 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 64
