跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Cannot Find Appropriate SSD Mounting Bracket
Hi. I'm trying to replace my hard drive with an SSD. The disassembly went great, but I got stuck when my mounting bracket wasn't long enough to use the iMac mounting system (it didn't have all three holes on each side). So I bought another one, and it didn't have threaded holes for the iMac mounting system. Then I bought a third one, and it works perfectly with the mounting system EXCEPT that there isn't enough length on the data cable. It just wont reach. The cable is just long enough to fit a regular drive. I don't know what to do. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I'm answering my own question. The data cable goes underneath the logic board and comes around the bottom of the computer, just above the RAM modules. There was a tiny bit of slack in the cable, so I gently loosened it and pulled up the slack. Perfect fit. I hope this helps someone else.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bjelliott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 132
