跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
My iPhone 6 can not connect WIFI
My iPhone 6 can not connect wifi. The wifi on/off button is always in grey. And the phone didn't react when someone calling me, even the phone is powered on. Sometimes the phone will turn off automatically. I didn't drop it on the ground or immerse it into water. What's wrong with the phone? How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
Your first step would be to try rule out software issue, restore the phone.
If that doesn't solve your issue, you will need to open the phone up, and replace the wifi routing flex which is attached to the logic board.
There is a guide on ifixit for removing the logic board itself.
Then you detach this part off the back of the logic board then replace it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Lesley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 144
