跳转到主内容
加入维修社区 - 创建账户
The first-generation XL-7 was Suzuki designed and had a body-on-frame construction. The North American version had a Suzuki-designed 2.5- or 2.7-liter V6 engine, on a rear-wheel drive-based platform with optional four-wheel drive. Beginning in 2003, European versions were also available with a 2.0-liter Peugeot turbodiesel engine producing 109 PS (80 kW).
How to test ac compressor 05 suzuki xl7
my ac is cold then turns hot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
First you should have someone with gauges to check the Freon level because there is a low level switch in the system. Next you would visually observe the middle part of the clutch on the compressor to see if it is spinning when it's not blowing cold air. If it's low of Freon odds are you'll need to fix a leak in the system. There should also be a cabin filter usually behind the glove box which could be stopped up causing the system to freeze up which I must say sounds more like to be your problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
momlvzajs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 442
