跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
Why isn't my touch working?
I recently got my iPhone's screen replaced after it had a run in with the cement. After I got it fixed, I noticed that some spots had no touch, much like a computer. I was fine with it, thinking it would gradually fix itself, but today the entire screen became untouchable. The home button and power button work fine, but there is no longer a touch compatibility. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hello
Try to push firmly the digitiser cable on the logique board maybe is loose that he make the touch screen not respond
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
Go back to wherever you got it repaired and have them replace the screen. You have a faulty part. It happens, but definitely get it replaced.
这个答案有帮助吗?
得分 0
添加一条评论
I agree with Brian take it back, and make sure to ask if they are using premium parts or aftermarket. There is a huge difference between the quality of the two and the aftermarket's, while they may work are not nearly as reliable as a good OEM Refurbished screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Olivia McCracken 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 104
