跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Proximity Sensor
Proximity Sensor not working on iPhone 3G 16GB White version.
I have:
removed my case
cleaned screen
cleaned around edge of touch screen
used air to blow out speaker holes
reinstalled apple 3.1.2 firmware
rebooted
What can I replace to get new sensors?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
You can get the new replacement from ebay. They are very cheap but it will take about 3-4 weeks to receive it unless you want it from the us. Cost about 10 USD. But make sure when you are replacing it to not destroy or damage the Sensor Flex Cable Metal Holder. Hope this helps you
这个答案有帮助吗?
得分 2
2条评论:
Thanks I am looking at them now, any idea how hard it is to replace? I have to assume it is behind the screen so I should not have to split the touch screen correct?
完成的
You almost have to use a pick tool to do the replacement. I find that is the easiest way to do it without damaging anything.
http://hectordtruong.blogspot.com/
完成的
添加一条评论
You don't need to split the touch.
There is one vague video on youtube which you might like to refer to.
http://www.youtube.com/watch?v=7KXIOyWXu...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darrell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 5,696
