跳转到主内容
加入维修社区 - 创建账户
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
Nexus 6 smd broken component
Hi, some time ago when i was dissasembling my Nexus 6 due to a camera replacement, i accidentally broke an smd component below the camera that is part of the screen well it only detached one pin ftom the two it has so i suited it in his place again and attached back the yellow transparent tape it has, i proceeded to reassemble the phone and all went good except when i low the brightness to certain point it starts to show Green lines and distortion but at a normal ir not so low brightness there Is no problem, Also i noticed an high amperage consumption and consequently a low battery duration i suppose it happens due to the broken component and want your advice if i should weld it again, it is very small and Is surrounded by many components as the same i broke, should i use heat gun? Or a soldering iron ? Tin welding ir liquid welding, or i just should heat the welding the component has and set it again un his place? There Is a photo of What im talking about (the photo Is from a broken screen i have but it shows the components)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I'm actually doing a similar repair right now and you need to use a soldering iron with a very thin tip. I just got this one: http://tinkersphere.com/electronics-tool...
Make sure the soldering iron doesn't touch any of the other components when you're reattaching it. It should be a very quick fix with the right tools.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryan C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 181
