跳转到主内容
It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
Elicits unending tone when GO is pressed
I used fresh batteries on a Big Trak, early 1980's model, which had not been used in more than two decades. After I program Big Trak, I press GO and all it does is elicit an unending, loud tone. I presume it is "stuck" somewhere. Who can repair this vehicle, if it is worthwhile or possible to repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you check to be sure the 9-volt is at 9 volts. Mine was at 8 and it was doing that exact thing. I am doing a once over before I put it up on e-bay, Mine is gray though. And I have the transport too.
完成的
添加一条评论
1个答案
sounds like the motors are stalled.
I would work the drive wheels back and forth by hand and see if that frees it up. Also make sure ALL the batteries are fresh. These are real battery hogs.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary Tameling 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 15
总计 346
