跳转到主内容
骑记电助力折叠自行车是小米第一次进入电动自行车市场的首款商品。 拥有250W高速电机,配备松下18650锂电池组。 禧玛诺内3速花鼓 以及力矩传感器,一次充电可以助力骑行45km。 它同时配备有行车电脑可以将您的手机通过特别的应用连接。 同时自行车也是可以折叠的。
20 个问题 查看全部
xiaomi qicycle battery replacement
where can i buy qicycle battery ? or how can i open the casing of the battery cause 18650 type is easy to find in my country.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
With increased interest in e-bikes generally, the cost of replacement batteries needs to be addressed. Proprietary brand battery replacement costs can run up to $1,000. There needs to be a rebuild option and iFixit would seem to be a perfect forum.
完成的
添加一条评论
10个答案
最有帮助的答案
There are several telegram chats with battery mods.
I’m running with a mod that allow to travel with 2 battery at the same time and hot-swap between then without powering down the bike. I can reach +80km distance (6ah+12ah)
https://3dparts459136784.wordpress.com/
Actualización (17/08/19)
Xiaomi Qicycle Custom Mods
https://t.me/Qicycleteros
这个答案有帮助吗?
得分 2
添加一条评论
could you show close ups of the structure that holds the batteries together. A tear down of the parts that keep the battery together would be nice too!
这个答案有帮助吗?
得分 1
添加一条评论
I fixed mine with a drill, once I saw back light flicker I put the charger on.
  1. Plug in the charger but Not to mains
  2. Using a drill spin front wheel until back-light fixed red
  3. Plug the power in. You will see everything is back.
  4. If your charger is flickering red, disconnect and do step 1
这个答案有帮助吗?
得分 1
1条评论:
Hi did you spin the front wheel in the reverse way? Did you need to turn on the bike power to get back-light on?
完成的
添加一条评论
Image above
这个答案有帮助吗?
得分 1
1条评论:
How to release that casing batery ...give me step by step to do that..
完成的
添加一条评论
They do appear on aliexpress from time to time.
这个答案有帮助吗?
得分 0
1条评论:
Here it is for you bit hidden on the page but is avaiable as a seperate item.
its under electric bike china if you put qicycle in the search look for the electric bike shop china seller under the bikes it also have it listed wont allow link on this page . look for the link that starts from $42 dollar as it in that one.
完成的
添加一条评论
hi
you cand find a battery here
http://s.click.aliexpress.com/e/NjmujYV
这个答案有帮助吗?
得分 0
添加一条评论
Still guys your answers don’t address the question. seanjoeakiller wants to know whether one can just open the case and put in 20 cells in order to replace the old ones. That would be much cheaper and probably would cost around 100$ instead of 300+ that the full battery pack costs.
Update (09/20/2017)
Check step 17 here. Apparently, the battery case can open with some heating and "good vibrations" but you will probably break the one-time-use clips the case has in the process. However, if your battery is dead by now, it's the best thing you can try I guess and see if the case can be closed again after being opened before buying a brand new set of batteries with case costing $300.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks for the direct link of the battery on Aliexpress... But... It s a ripoff as I get the full ebike for that price !!!
这个答案有帮助吗?
得分 0
添加一条评论
https://www.aliexpress.com/wholesale?cat...
This is a link to a search for the battery on AliExpress, you can find many replacements, with prices starting at $219.99 (USD).
The real problem with repair or recreation of these batteries is opening the unit without damaging it. I'd love to be able to open the battery unit and test the cells to see if one is faulty and preventing further charging.
I'm a hair’s breadth from buying a replacement battery myself, as my battery won't charge anymore and Xiaomi don't support the cycle in my region. But that $219+ replacement price isn't a small amount, so I'm struggling on without the battery for the moment.
这个答案有帮助吗?
得分 0
3条评论:
I removed the battery, opened its casing, and split the battery in two as then it was within the air transport laws (Australia). I don't recommend this unless you really know your electronics. The cells are spot welded in place and can get hot when removing. I never got it to work again..
完成的
I have photos of seperated battery internals
完成的
Definitely NOT user serviceable then?
No wonder they never used this style battery unit again.
Thanks!
完成的
添加一条评论
It looks great as usual. Thank you so much for sharing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
seanjoeakiller 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 18
过去 30 天: 66
总计 15,685
