跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s is having troubles with the telephone network
Hello, since this weekend my iPhone 5s is having troubles with the telephone network.
During a phone conversation, there was a cut.
I tried to call back my correspondent unsuccessfully. I tried to send a text message, and it couldn’t be delivered.
I then restarted my telephone, but I did not yet manage to make a call.
I eventually exchanged with my correspondent with Facebook messenger. Which worked very well.
Afterward I was able to exchange text message with a friend who also has an iPhone, via the exchange of iPhone messenger it also worked.
I thought that the problem was settled and I did not restart my telephone again.
It is only the next day, by trying to send a text message, that I noticed that the problem was not settled yet.
I restarted it again and I received text messages from the day before, and missed calls.
Since then, it went out and flared up again alone ... It had done this once last week.
And I sometimes receive text messages 30 minutes after they are sent to me ...
And it was overheating at some point the last week also.
Has anybody already had this problem and if yes is there a solution?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
This question was migrated from http://meta.ifixit.com/Answers.
完成的
添加一条评论
3个答案
Seems like a bad connection with your 3G board that antenna.
Does your phone show any signal from your service provider?
You might need to replace your phone antenna.
这个答案有帮助吗?
得分 0
添加一条评论
Thank you for your answer.
I'm gonna check the antenna, I don't know much about it but I will ask a friend to help me
这个答案有帮助吗?
得分 0
添加一条评论
This is not a issue with your iphone. This is a issue of network problem or outgoing and incoming msg server of your your gsm or cdma network. Sometimes it called call drop.
Try to use your sim other mobile and check whether problem is still there or not. Dont need to check antena. First check that your sim network is fine with other mobile. Also called to customer care and ask from msg server number and manually change to your mobile.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
val_lou 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 55
