跳转到主内容
The LG K20 Plus Android smartphone was released by LG Electronics in March 2017 as part of the K Series. The LG K20 Plus includes model numbers LG K20 V, LG VS501, and LG TP260.
How to fix my K20 plus cracked screen?
I dropped my new LG K20 Plus and the screen shattered.
How can I get it fixed?
Where to buy a screen?
What all parts do I need to buy?
Can I do the labor myself?
Do I need special tools?
If I can't fix it myself, where can I send it and how much will it cost?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
8条评论
Can i fix it myself. And what all has to be replaced
完成的
Is the digitizer glued on the display side or on the glass side of the screen, also what would be more effective for this repair... Dry ice or heat gun. i considered dry ice due to the fact that it is less likely to destroy the screen than heat is
完成的
my friends cell phone screen is cracked but the cell phone still works!!!!!!!
完成的
Cracked screen for LG K20 how much does it cost
完成的
My Phone Broke because I was playing with a VR headset the holder for the phone shot out my phone. Model (LG K20 PLUS)
完成的
显示更多的3条评论
添加一条评论
3个答案
已选择的解决方案
Created this repair video just because I seen this thread. https://youtu.be/59ZarYHPPrE
这个答案有帮助吗?
得分 4
1条评论:
Dude you are awesome! This is the process right here folks! I watched to confirm.
完成的
添加一条评论
I also have the same problem. This is my second LG K20 Plus phone and the screens on both broke with on a month of my purchasing them. The first time it slid off my bedside nightstand and shattered when it hit the floor (a drop of about 2.5 feet) and the second I simply had the phone in my pocket with nothing else in the pocket yet the pressure from my leg was enough to crack the screen.
My honest guess is the plastic body of the phone is too thin and so the phone body flexes cracking the screen. This is simply a poorly designed phone. Avoid it.
这个答案有帮助吗?
得分 1
6条评论:
Replacement glass screen available here while the how to video can be found on youtube
https://m.ebay.com/itm/332318337221?_trk...
完成的
Yeah so I call BS to the "you can find the teardown video on YouTube" I have scoured the internet and can't find a single tut/video on this phone..
完成的
Ì agree. I found 1 on YouTube. But it was like he was working on a different phone. All of HIS components just came right out, they weren't affixed down like all of mine were. After he pulled off the last component he says, ok so there you go. Now just put it back together in the opposite order that you took it apart!! I was like, wtf??? What about my cracked screen?
完成的
Yeah agreed. The 1 video on YouTube is for a different model, which is why the phone was different. I actually figured out that all those holes on the back where it looks like you are to pry up the back are misleading. The entire bezel is attached to the back casing so after you take out the battery and all of the screws the bezel comes off next, not the back casing only.. Hope that helps! If I ever have to do it again I will make a video and post to YouTube.
完成的
Maybe you should read comment 2 on this page and you will see the link to the youtube video.
完成的
显示更多的1条评论
添加一条评论
just saw this video, i'm going to try it at home as well.
https://www.youtube.com/watch?v=szo_MCab...
这个答案有帮助吗?
得分 0
1条评论:
Coincidentally his video went up a day after mine. Lol.
完成的
添加一条评论
添加你的答案
Perryinjax 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 28,785
