跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Powering iPhone 5s on without home or power buttons?
I have an iPhone 5s and both the home button and power buttons are broken. I use assistive touch to use those functions when needed. Today my phone died while it still had plenty of battery. Normally I can plug it in and it starts up without a problem but today when I plugged it in the screen stayed blank. I don't know what to do and any help would be appreciated! Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
If your phone has had a broken power button for awhile and you let the battery drain often to the point of the phones turning off then there is a chance your battery may need replaced. Lithium ion batteries will have a shorter lifespan if a person let's the battery drain below a certain percentage often (below 20-30%), especially if it's to the point it shuts the phone off. I know you mentioned that the battery still had plenty of battery left but the software that monitors the battery percentage may be inaccurate at times especially if your battery has an issue. Since plugging the phone into the charger does not power it on eventually like it should then I would start by inspecting the charge port for damaged or missing pins or if it's dirty and needs cleaned. If the charge port and your charging cable appear to be ok then you may consider checking the battery next. You can use a volt meter on the batteries connector which plugs into the motherboard to check it's voltage if desired. Or replace the battery. You did not mention if you have tried plugging your phone into your computer to see if iTunes can recognize it. If you can get iTunes to recognize the phone then it could be a software related issue or possibly a screen issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 159
