跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
Cracked screen, blurry photos on front camera
Hello everyone, I dropped my S7 on asphalt and cracked the screen. It still works perfectly except the fact that the front camera takes blurry photos...light seems to be seeping in through the cracks and thus makes the photos look too bright and sort of whitewashed. So I was thinking that maybe it's better if I just take off the cracked parts in front of the front camera.. or is that a bad idea? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Sadly, you should remove the glass, but you can't simply remove the glass with high risk of damaging the LCD. You best replace the whole display assembly.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I did that and it made it far worse....dont!
这个答案有帮助吗?
得分 1
添加一条评论
You'd better replace a new screen, the display is easy to damage without glass.
这个答案有帮助吗?
得分 0
添加一条评论
I would not recommend taking off the glass it could be dangerous and make permanent damage to the phone I would rather replace my phone
这个答案有帮助吗?
得分 0
添加一条评论
Do it that always helps ngl but you gotta be carful when doing it have your camera on when you do it so you see when it’s not blurry
Don’t get water in your phone
Or any liquid at that
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Czarina Del Rosario 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 7,541
