跳转到主内容
发布于2013年11月22日的微软第三代Xbox游戏主机。
My controller randomly disconnects
So my Xbox one controller will start flashing then turn off then kick me offline. It does it more frequent than ever right now. I heard something about the wifi card will work and help but I wanted to see if y'all had an answer. How do I fix?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Thank you!!!!
完成的
I am facing a similar problem. I will be playing a game and my controller will randomly disconnect but the light will stay on. My screen will then state “you need a controller to play this game.” After I take out the batteries and put them back in, it will work for another few minutes. If I don’t use the battery way, the controller will reconnect in about 10 seconds. As you can imagine, this is very aggravating when playing online games. Any suggestions?
完成的
添加一条评论
2个答案
已选择的解决方案
Yes the WiFi card was my initial thought as i read what you explained. it would certainly be the first thing i would try. if you really wanted to put it to the test, keep your controller plugged in with a USB cable to the console. if your internet disconnects and the controller stays connected i am certain its the WiFi card. its a pretty easy thing to replace thankfully. only mission about it is opening the case
这个答案有帮助吗?
得分 0
添加一条评论
There us a known issue with xbox ones being in Instant On. I would suggest changing that to Energy Saving and see if it fixes the issue. Mine was doing the same thing til I found that solution. No more problems since.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn Lindeborg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 4,554
