跳转到主内容
The Xiaomi Redmi Note 2 is an Android smartphone sold by Xiaomi, a Chinese multinational electronics company and released in August 2015. The Redmi Note 2 was sold in two variants, the standard and the Prime. The Redmi Note 2 can be identified by model number 2015051.
18 个问题 查看全部
Phone shutting down randomly, unusable.
My Redmi Note 2 is randomly shutting down even when is connected to the charger. This started to happen after the battery swallen up, which was replaced with an original one.
I read online it coud be a rom problem but the is currently running the official global rom and I tryed the official chinese one but the issue persist, TWRP is not installed, fully stock rom.
So this can only be an hardware issue, any thoughts on what is causing the problem?
If I replace the motherboard will it fix the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
this could be alot of issues, the thing i think of when a battery swells up makes the phone unusable is that is could leak form the battery on to the motherboard and make it unusable, so yeah you could try a new motherbord but you never know untill you tested that out..
Update (06/29/2017)
and are you using an original charger?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bruno Goncalves 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,028
